My house was built 100 years ago, is in the northeast and the pictures show the interior of the basement. The foundation is 18-24" thick made of stones set in mortar (no rebar or cinder blocks anywhere). I've been living in it for 20 years and the house hasn't settled any since I've moved in so the cracks you see are (I think) just old mortar pointing and dry plaster and paint peeling away. I haven't painted in 20 years so the paint is probably from 30 years ago. We have a very high water table AND the basement is around 4' below grade. It's pretty humid as a result but we don't have any seepage and I don't want to seal the wall with a dry-lock paint because I've read that that could cause different problems which we don't need to get into now.
So my pre-Christmas holiday project is to finally paint the stone and make it "nice" but the basement has a 6' ceiling so it's not useful as living or rec space. Just want the walls to be presentable. You can see some areas over the sink that I've painted in the past using excess paint leftover from other projects - basically I want to do more than that.
I know that I need to scrape off all loose paint and plaster, but then my questions are:
1) what to seal the long cracks with? a concrete caulk or just regular silicone or whatever's on sale?
2) do I need to prime it all?
3) I think I would want to use semigloss as the final coat because it'll be better as far as dirt goes plus it will brighten up the area.
Hopefully Home Depot has good enough quality paint for this. Behr? I usual buy benjamin moore paint but that seems too expensive and overkill for this project.
I appreciate any advice and direction you may offer!
Thank you,
Andy
Thank you,
Andy
