1 - 9 of 9 Posts
I finished putting up new siding and need to start painting. It’s about 1000 sq ft with lots of windows, etc, so I plan to paint with a 4in brush rather than spraying. Using Benjamin Moore Aura. My main question is what should I do to clean/prep for the paint?
It’s pretty clean. There may be a few spots that I need to wipe off. I think scrubbing it all down with TSP or something similar would be overkill for new siding.
LP recommends painting directly over the factory primed surface.
I think I’ll just take a wet rag to spots that look like they might have gotten dirty during installation. I’m a bit nervous as I’ve never painted the exterior of a house. Certainly not a job you want to get wrong.
· retired painter
It's not that big of a deal. The main thing is to not paint over dirt that can be wiped/scraped off [smudges are ok]. Normally you don't want to paint in the hot sun as it can cause the paint to dry too fast.
· Premium Member
Smartside is about the easiest substrate to paint. You could even use a roller to speed up the process. Just use the roller sideways and roll horizontally, then you can backbrush with your 4 inch brush and also paint the overlapped areas.
1 - 9 of 9 Posts
