Hello,
I'm new to this site. I have hopefully a simple question:
How long will it take to paint an exterior front door? I ordered the door with painted already but just received a letter from the HOA stating that the paint will need to be changed.
Also, how long will it take to paint 6 shutters? I can either paint the door myself and hire someone to paint the shutters or have that person paint everything.
Thank you.
John Doe
It depends on your skill level and the tools you're using. A painting company should be able to have it done in a day (probably less), I would say. Doing it yourself will take longer unless you spray the shutters and door.
Tiger, welcome to diychatroom. You need to provide more info. Your question raises the following in my mind.
Door:
What type of paint will the factory apply? Will it be a hard, glossy type enamel that would make me feel more comfortable first coating with a bonding primer?
Is it just a door slab, or is it a unit with sidelight(s)? Does the door itself have any lights (glass)?
How much detail does the door have?
Does it have tricky hardware that I'll have to remove/replace?
What do you want to paint it with, latex or oil? Oil means completion over two days.
Shutters:
Are they first floor second floor, what? Easily accessible, or will some require a forty foot ladder to access?
Are they hung (on the wall, :laughing:)?
Are they wood or stamped out vinyl? Paneled or louvred?
Are they new, or do they require washing?
I always prefer removal, as opposed to painting/cleaning them hanging? Do you have a shop area where I could lay out six shutters, or do I have to take them offsite?
On both projects there are other considerations, these are a few. The point is that whenever you ask questions about time/money for a particular task, even with pictures, there are many variables that come into play, including you and the perception the painter gets of you. Whenever I look at work, I size the owner up as well as the task. If you seem the kind of guy who's not going to be happy if every i is not dotted, I have to take that into consideration, and I know more time will be involved in making it just right. I ask people their opinion of work that looks fairly recent, and if they think it's great, and I think it's not, I know I don't have to be too anal. That consideration could, conversely, allow me to cut back on time, therefore money. There are just way too many variables.
