1 - 18 of 18 Posts
In another thread I took a new primed exterior door and painted it and had a problem with paint drying too fast. Simple job was a pain:vs_mad:.
This door is an exterior door in the garage into the house, with weather stripping. I searched the net for paint sticking to weather stripping and see answers all over the place. Don't let weather stripping touch paint for 24 hours up to 10 days, replace weather stripping with silicone weather stripping, masking tape weather stripping. What to do?
This is Sherwin Williams interior Super paint in a satin finish.
I would use oil based paint, which will harden and not be sticky. Latex paint contains plasticizers and will tend to get soft and sticky in hot weather, which FL has plenty of. Whatever you do the door has to come off or remain ajar till the paint dries.
Reactions: jjrbus
· retired painter
I can't remember the last time I painted a new exterior door that didn't have removable weatherstripping. I like to remove the weatherstripping and reinstall it a few days later after the paint has had enough time to dry.
Many steel door manufactures state that using an oil base paint will void the warranty. The main reason is because the metal is thin and if it expands/contracts with temp changes oil base coatings can crack/peel and take the factory primer with it. Latex paints will flex just enough to prevent that issue.
Thanks for the responses, I should have mentioned I removed the door and laid it flat to paint. Nothing screams crap job more than paint all over weather stripping!
Now that I think about it some of the shelves I have painted with latex paint stayed sticky for a long time!
I have a set of metal swinging patio doors to do also, just the inside. What do you think of having a can of automotive type spray paint made? I have heard of it but know nothing about it.
Discussion Starter · #9 ·
Sounds like you need a better quality latex paint. Many of the cheaper latex enamels never dry to a hard film and blocking [sticky] is a problem. A quality latex enamel won't have that problem.
Sherwin Williams interior Super Paint in a satin finish. This is in the garage with constant high humidity and temp.
· Premium Member
All-Surface Enamel or Snap Dry would have been better choices than SP, although, really, SP should have been fine. A trick to keep the weather stripping from sticking to your newly painted door is to coat the weather stripping with a thin layer of WD-40. I often have to do this because homeowners want to be able to close their doors before nightfall.
do NOT use oil based paint (t becomes brittle as it ages, and has poor color retention). It is considered inferior to 100% Acrylic Exterior Paint.
I like SW Emerald Urethane for doors (which can actually be used for interior and exterior side of door).
Discussion Starter · #13 ·
I have been scouring the net and one suggestion is using painters tape on weather stripping.. Since this door is inside the garage I have the option of leaving it off for a few days. I sealed the doorway with plastic, inconvenient going around but better than the paint peeling off door.
Why dont you put the door on, but just leave the weather stripping out for a couple days? I dont understand.
Even at clients houses, when I paint their door, I finish the job and tell them to put it in themselves in a couple days, if Im gonna be gone.
I have painted doors with oil based paint for 50 years with no issues. Never a sticking door or paint failure. Most have oil based primer from the factory. Auto body shops just started using water based paint because of environmental reasons, not because oil paint was no good on exterior metal surfaces. I have seen many doors in hot weather where latex paint made the door stick, creak, and some have paint that pulls off onto the weatherstripping. I remove the door, lay it on sawhorses, and spray it. They have a finish as nice as a new car.
Reactions: jjrbus
· retired painter
..........because homeowners want to be able to close their doors before nightfall.
The door can be closed and locked without having the weatherstripping install. It might be a little loose but once locked [especially with a deadbolt] it will be secure.
Back in the 80s I worked for a painting contractor that was part of a class action lawsuit. The suit claimed that our cheap paint [it was cheap] peeled. It was proven that the paint peeled because the thin metal flexed during temp changes. Not only did our paint peel but it also took the factory primer with it.
1 - 18 of 18 Posts
