1 - 7 of 7 Posts
I'm looking for abuse tonight. Yes, solid stain.
Someone please reply to this plan, thanx.
condition;
**structurally perfect 15 yr old PT decks (3)
**deck flooring greyed and blackened by some staining, and grain is very rough sometimes splintery
**3 yrs ago applied cabot's au timber honey teak but it's washed out now
PLAN:
1)pressure wash with 20% bleach/water mix
2)lightly sand with orbital (or belt?)
3)apply cabot's oil based primer
4)apply solid white cabots (or other brand) acrylic latex 2 coats
How bad is this plan? I'm gonna be in this Massachusetts home a long time.
I took it upon myself to just change your plan...:whistling2:
Primer and solid stain is a bad idea because it will look terrible after foot traffic and everyday use.
Revised PLAN:
1)Strip
2)pH balance
3)Sand with orbital sander
4)Allow to dry a couple days
5)Apply Armstrong Clark Semi Solid instead.
If you were trying to get away with having to maintain your deck you were mistaken. 2-3 years just lightly strip and pH balance. Apply another coat. It will look a whole lot better than the solid stain plan.
I'm going to agree in principle with those changes to the plan.
I would:
1)Strip
2)pH balance
3)Allow to dry a couple days
4)Sand with orbital sander-60 grit
5)I hear good things about Armstrong, but don't have any experience with it. I have used Ready Seal
I'd avoid the solids, so it will be easier to apply the next time. Here will be the procedure next time:
1. Lightly clean
2. Stain
3. Enjoy
staining
But semi-solid shows the grain - a disaster here. So you convinced me not to do anything. I was looking for the latest solution but looks like the paint gods have not found a solution in recent times. Thanx, anyway. You saved me some pain.
clear sealant?
I wrote yesterday as to how to seal my grey weathered deck and I haven't yet received a reply. I wonder if I asked in the wrong forum. Looks like you got good advice!
Solid vs Semi Trans "can" be a matter of preference but semi's hold up better on horizontal surfaces especially traffic areas. PLEASE, no matter what you do, keep latex products away from the deck.
1 - 7 of 7 Posts
