Hello, I am a newbie home owner. I have a house that has brown paneling on the walls with unfinished crown molding, wood base trim, and trim around all of the interior doors. I want to paint the paneling as well as all wood base, trim and molding. The quarter round on the wood base is a lighter wood that separates the wood base and the wood floor. I want to keep the quarter round wood-stained.
Is there a particular order in which to paint these? or does it matter? The crown molding and trim work have never been painted, so would I have to use a primer on these as well as on the dark wood paneling? If so, what do you recommend?
Also, the nails used to attach the wood paneling are exposed. Do I need to tap those in with a nail punch and fill the holes prior to painting? If so, do I use wood filler or spackling? What do you recommend?
Thank you for your help!
