1 - 12 of 12 Posts
· Rubbin walls since'79
I don't thhink "enemel" is such an antiquated term. there's regular interior paint and then there's enamel when toughness (or water-resistance) is required.
tnx,
So is any semi gloss also an enamel? And if not, why?
Enamel these days seems to be applied to anything above a flat.
And those things being labeled enamel have all sorts of degrees of hardness.
But that is beside your question- use something with some sheen. Call it enamel. Many do.
Enamel meams "hard surface paint." Nothing to do with the sheen.
It can be bought in several differant sheens, also can be oil or water based.
So he should use an eggshell for his powder. I would . Works great.
Is Regal Select eggshell an enamel?
I know painters that use Regal semi on trim. is it an enamel?
I think WB Impervo is kind of soft- even after cure. Is it an enamel?
I like Muralo WB Ultra Semi. I think it's an enamel...
Zinnser 123 primer is really hard when cured. is it an enamel?
The definition is a hold over from when oils ( yes, ones with sheens) dried and cured really hard. Some WB approach that, but not many.
Most of the paints on your list were baked on specialty finishes.
Not going to argue the point, because even I use the term, but it is VERY loosely defined.
· paper hanger and painter
better watch out, you know who might be reading this:laughing:
· Member
I think the one thing we've learned in the biz is that there is a ton of variation, from brand to brand, and even within the same brand. As applicators we don't necessarily need to understand the chemistry, but we do need to know what each product can and can't do and how to achieve the look and meet the needs of our customers. That comes from knowing the range of products available, experience. We can't just trust the paint companies, not so much because they deceive, but more so because of interpretation.
As to enamel, I try to keep it simple. I consider enamel any film forming coating that forms an elastic "skin". It may not pass a paint chemist's muster, but it works for me. I have my go to finishes that I use mostly, but have some understanding of different products and where they might be required or a better choice. Just as flats, etc, have a range of sheens, semi-glosses, etc, have a range of hardness. So to BJ, yes, all of those finishes that you mentioned I would consider enamels, but not 123 which is not a topcoat.
1 - 12 of 12 Posts
