Just a comment that I think is related to painting a straight line. Which I think we are talking about.
I would argue, there is no such thing as a straight line between the wall and the ceiling....yes some framing rocking get close.... (There fore, I would point out that a mechanical system (the roller pad) which has to relay on some imperfect planes/angles system is not necessarily any good answer.
I would argue that with variation in framing / rocking, a pro/ experienced painter has to often "split the difference" or decide on the primary visual view the wall will be viewed from.
Most times a wall/ceiling line will be viewed from 90 degree orientation... therefore a straight line on the wall becomes a defining critera.....even though some wall paint may end up on the ceiling or vica-versa.
Sometimes/ very-seldom, though the primary view may be down the ceiling line, whear as you want the ceiling color line "dead" straight.
I'm very reluctant that any mechanical pad system can produce a more visually appealing "straight" cut in an imperfect ceiling/wall framing than a more precise brush in the hands of a semi-experienced painter. employing their common sense judgement.
I will admit, if you are brand new to painting, you may be better off with a "roller-pad" system. And if you have to ask whether to paint the ceiling or the wall first.... better use a "roller-pad" the first time untill you learn trim technigues of painting.
