I tried to paint an aluminum handle and got some awful results in the end. Apparently, the clear coat I used is incompatible with the enamel. Please see the attached pictures.
Steps:
- Plasti-kote sandable primer (fast-drying lacquer, acetone, toluene, xylene)
- 2 days drying time
- Rust-oleum gloss protective enamel (acetone, dimethyl carbonate, petroleum distillates, aromatic hydrocarbons)
- 4 days drying time
- Rust-oleum gloss clear (acetone, n-butyl acetate, glycol ethers, xylene)
The clear coat ruined the enamel almost immediately. Note that I didn't use the enamel on the inner surface and just left the primer there; the clear coat did fine in that area.
Any comments/suggestions?
Thank you!
Steps:
Thank you!
