*roflol*Fan vent can be flex 3" aluminum run to where it can point out existing attic vent. I avoid protrusions through the roof, simpler, cheaper and one less protrusion to leak and work around and just a cleaner looking roof. I've seen guys that think everything has to go through roof where it is, they are mistaken and they have too many roof jacks, unsightly, expensive and more to maintain and keep from leaking. I will even run all plumbing vents together with appropriate slope and make just one 3or 4" vent through where possible. This is within code as well.
I find that setup annoying, personally. Maybe you or your guests will too. If it's important, you can hook up a humidity sensing fan, although they're more expensive.for a palce this wet, would book fan to light switch, when in use, fan is on
right now this is not about an exust fan, when i get to that point in my remodeling i will as for options about them.I find that setup annoying, personally. Maybe you or your guests will too. If it's important, you can hook up a humidity sensing fan, although they're more expensive.
#1 A bathroom with no powered vent will be nothing but trouble.
Make that a #1 priority to add a vent that exohost:furious: all the way to the outside.
Main reason it's no longer legal to have just a window in a bathroom.[/QUOTE]
copy and paste this somewhere, it is easy,I believe you have written this wrong about 6 times this week, spell check is that ABC thing in the upper right hand corner
exhaust
exhaust
exhaust
In Joe's defense I must add that his computer may not have that handy ABC thing in the corner. Mine doesn't.#1 A bathroom with no powered vent will be nothing but trouble.
exhaust
exhaust
exhaust
But Joe...seriously.. everybody makes typo's from time to time, but its easy to see a certain painter is going insane.
He has tools ya know and personally I wouldn't take the risk that the spelling corrections may end up being painted somewhere.
Chris...while you are there will you please CONSIDER fixing DIFFERENT..
Chris...while you are there will you please CONSIDER fixing DIFFERENT..[/QUOTE]
Really? I just assumed( I know) that this site was viewed the same by all.
Guess not:whistling2: Sorry about that. There are free spell checking tools for different browsers through.:yes:
In theory for the most part I quite agree. We are not here to be corrected grammatically or to act as grade school teachers for others.you know what ? who cares. Personally i think its mean spirited to point out spelling mistakes.
