A few years ago we contracted the re-painting of exterior metal railings to a painter who specified that they would remove loose rust, and then prime and paint with rust-paint. The rust later returned within a year.
This year, I’ve discussed the subject with many others, who convinced me that the way to go is the use of a “rust converter”. The brand ‘Qurox’ was recommended although the idea as I understand it is relatively standard…an organic acid (usually tannic acid) mixed with a co-polymer, and the combination reverses the oxidization and seals the metal, acting as a primer.
The manufacturer of Qurox recommends scraping/grinding loose ruse off, then applying 3 thin coats of Qurox, with an hour to dry between each coat. Although they are not in the paint business, he recommended that we complete the job with 1 coat of Epoxy paint.
Our painting contractor (different person from prior years) agrees with all of this, expect for the Exoxy paint. He commented that Epoxy paint is excellent, but is also very expensive and he didn’t see the benefit from the added expense, especially in light of 3 coats of Rust converter.
We’re in Canada, where Oil-based paints will be largely removed from the market by next Year. Our painting contractor recommends using as much Oil based paint while we still can.
He didn’t mention this, but one possible consideration is that the original paint (7 years ago) is oil-based paint. Since we won’t be stripping, and the only primer will be the rust-converter, is it fair to say that Oil-based would work better? And if we were to move to epoxy paint, we would either need to strip the existing oil-based paint, or prime it with something in addition to the rust converter?
A final consideration, I read that Epoxy paints, while strong, don’t hold up well to Ultra-Violet radiation. These metal railings get a lot of sun.
The last recommendation I received was to use a "Urethane system" such as Pitthane, but warned that it would cost quite a bit.
I didn't get a clear understanding of what's the issue with standard oil-based metal paint, if oil-based paint is still available? I've seen that it holds up well over many years if the metal is properly prepared.
Thanks for any suggestions.
