I'm wanting to do paint & grain on a couple of cupboards that are currently glossed. Would the following plan work?;
Electric sander, primer, then paint and grain? Xx
Thanyou, I shall buy some terps to get started then!Hey Amanda,
Before you begin sanding I would suggest you wash the cupboards first using TSP. Secondly, when you say prime...what primer do you plan to use?
If by terps you mean turps or turpentine (technically not the same thing), I would suggest not using that as a cleaner. They are both good degreasers but could leave an oily residue on the surface. As degreasers, they're generally used on things not intended for painting. I will generally use paint thinner as a spot degreaser, but never as a whole cabinet system cleaner. There are a number of cleaners designed for paintable surfaces such as TSP and Dirtex and KrudKutter to name a few. They're safer to use and easier on the body. Keep it simple.Thank you all for your help, made a step by step list from what you've all told me and I think I know what I'm doing now! :thumbsup:
Do I need any specialty stuff to take the terps off so it doesn't affect the primer going on?
