My 2004 Hyundai Elantra gets P420 check engine light that goes away when the fuel tank is at about 80% then comes back on when it drops to about 60% and stays on until I fill the tank and the level goes down to about 80% again. Can you give me some ideas as to where I should start looking? Here is my scanner readings.
FUEL SYS1 CL
LOAD_PCT 13.7
ECT –
SHRTFT 0.8
LONGFT 6.3
RPM 767
SPARKADV 4.5
IAT(C) 9
MAF(g/s) 2.29
TP(%) 6.7
O2SLOC B1S12–B2S
O2B1S1 0.490
SHRTFTB1S(%) 3.1
O2B1S2(v) 0.035
SHRTFTB2S(%) N/A
OBSDUP OBDII
MIS - GREEN CHECKMARK
FUE - GREEN CHECKMARK
COM - GREEN CHECKMARK
CAT - GREEN CHECKMARK
EVAP - X MARK
O2S - X MARK
HRT - GREEN CHECKMARK
· Naildriver
P420 is a bank 1 catalytic converter error code. Not sure why it is reacting as you indicate with filling the tank, then depleting it a percentage. Have you checked your O2 sensors ahead of the cat
Or your gas cap?
If it's running good it could be the downstream.
That code can be many things because it just means that cat is running under efficiency. A 5% percent efficiency can light up the code.
There is a product called Cataclean you can put in your gas tank but I've never used it.
