I have a couple questions about the drains on my a/c unit, think it is a Goodman. The S line goes directly into the pan and the P wraps around and drains into some plumbing.
1) If I understand from reading about this this primary line should be plugged or capped but not permanent. Cap can be removed to clean out drain.
2) Since condensate is coming from the S line and draining into the pan does this mean the primary is plugged? If so can I pour water or something into the open tube?
Cold air blows from the P line when A/C is running. I guess this is typical. Just rather not cool off the attic but the house.
A image should be attached.
Thanks
Thanks
