How will it not leak through the nail holes from the old shingles if the shingles are blown off?
I like synthetic and do think it has a purpose, just not in every application.
Most blow offs we see, the nails stay down on the deck and the shingle tears through. The nails seal themselves in this case and as long as you are running a button cap staple or nail, the underlayment is basically sealed.
Either way, you aren't getting a gushing leak from a nail hole. My concern (in the case of wind damage) is the felt being torn back and at that point, all the water is going right under the felt on the next layer and in at the next plywood seam in the roof.
For those that can afford to say it's only $250 more, by all means just go for it.
Does it really matter if it's better or not, no.....
It's going to be under the shingles, if for some reason the shingles blow off is it covered under some warranty.???????
No mattrer, you have enough money so why question it....
I disagree for the reasons stated above and for Pat's reasons below.
It isn't the warranty that matters, the stuff just offers better protection.
While I haven't used the OC synthetic, the discount stuff I have used is great. The shingles may blow away in a severe storm, but the paper stays where it's put.
It also doesn't wrinkle if it gets wet, so their won't be any telegraphing through the shingles if it's left over night and there's some dew.
Is it necessary? No, it isn't, but for what I imagine is a reasonable %wise upgrade, it protects better and makes sense.
+1 on the install end of things.
It is as much a benefit, if not more, to the install end of things. Better slip resistance, doesn't wrinkle up, stays down if a thunderstorm rolls through.
We have some thunder clappers that can roll through without much warning and when the synthetic is down...it isn't coming up. We can get the thing dried in and know that we are water tight at that point. I have sat by with baited breath when the felt is down from time to time.
