Ok, for my intro to these forums I think I have a good one for everone...
I have a condensation pump that I installed last summer. Prior to this the AC & humidifier dumped in to a floor drain, however due to some serious plumbing issues which cannot be resolved without tens of thousands of dollars, I was forced to plug all of my floor drains in my basement. My condensation pump had to drain somewhere so I sent it over to my sump well (a plumber said this was acceptable).
My problem is that when the humidity gets really high during the summer or when the humidifier run, the condensation pump gets overwhelmed and shuts everything down until it catches up...it also dumps some water on the floor from the piping on the furnace.
My run from the pump to the sump well is around 47 feet including a 9ft rise. I'm using 1/2in OD, 3/8in ID flexible tubing for my run and I have made sure there are no kinks and it is on as much of a downward slope as possible. My pump is a Little Giant VCMA-20ULS 1/30HP, 80GHP.
Last detail is that I live in a condo so structural changes are out of the question (but all this stuff is mine to deal with - gotta love it). Also, if it matters for code purposes, I'm in Michigan.
My questions are;
Do I need a bigger/stronger pump?
Do I just need a bigger tube? Another tube?
Would cutting 2 ft from the rise do it?
Is there something else? Let me have it! I've been trying to figure this out for nearly 9 months and I'm at wits end.
My questions are;
