living room floor kind of has two levels, one surface is about 1 inch higher than than the other. I want to put on an other layer so the surfaces are level. what kind of cement should I use. For prep work , should I scrub the surface with some acid solution or do I need to grind it? The surface seems to have some kind of paint (see attached). thanks
