I've been living in this house for 3 years now, and I've got an old Caloric RWS202 wall oven that came with the house. I just burnt out my oven's glow igniter for the 3rd time. Its an old house with an old oven, but that seems a bit excessive doesn't it?
The first time, I didn't know it was the igniter right away- it would glow, but it wouldn't start the gas. I left it on for a while hoping it would start (maybe it wasn't reaching the right temp?), and when it simply wouldn't go, I called an appliance repair guy. The repair guy tested everything and said that its probably the igniter bar even though it glowed. He replaced it, and sure enough it worked fine after that. For about 7 months. Then it burnt out again- this time it wouldn't even glow. He gives a year warranty on repairs, so he came back and replaced it again. That lasted about another 5-6 months. Since it was past the year, I ordered a replacement part online myself (matched part number on Amazon.com) and installed it. This was January of this year. Well, this past friday, it stopped glowing once again. This is barely 3 months later!
The only explanation I have is that there appears to be a small hole in the metal plate (flame spreader I think?) right above where the igniter attaches.
I'm wondering if when my first igniter went bad, I accidentally burnt a small hole by leaving it on hoping it would start? Is that even possible? I mean this thing is designed to handle flames spreading all over the place, but I have no other way to describe why there appears to be a small hole only there.
Anyway, I noticed that when the oven would ignite, you could see some flames rushing towards that hole. I'm guessing the hole acts as a source of oxygen so the fire is attracted there. Could that be burning out the igniter prematurely? It could be my imagination, but I think the hole got bigger since the first time we replaced it.
I tried to source a new flame spreader/burner assembly, but it seems that no one makes them anymore for this model. I tried the usuals like repair clinic, ebay, even just googled the OEM part number. So I'm stuck with this one for now. Is there anything I can do to patch up this hole? I tried aluminum foil, but that just disintegrated/burnt up. Am I just doomed to replace the igniter every few months until I can afford a new oven? Is the hole not even the problem?
Thanks for any and all insight!
