Any one have any average co readings for nat gas ovens. I have one as it cycles at 400 deg. it runs up to 225ppm and then starts to drop and then of shuts down on temp and goes through another cycle. If I run a hotter temp the co readings are lower and the same in the oposite the lower the temp the higher the co. Always under 400ppm durring operation.
The stove is very clean and only 4 mos old. On a full cold start it spikes to 625 and then drops. I have tried to adjust air shudder, leavel of burner and hight of burner shield above burner. This is the best I could get.
Does this sound in line with normal operation?
Thanks in advance
John
Thanks in advance
John
