1 - 7 of 7 Posts
I am getting ready to add some ledgestone on he outside front of my house.
The area that I am adding to is the only non stucco part of the house.
How it sits right not, outside is panted plywood, to rock wool, then framing, then drywall on the inside.
My question is when I do this should I pull the ply and put some house wrap ans some ridged foam. or should I put some waterproof sealing paint on the wood, or cement board then the ledgestone.
Discussion Starter #7
Stone people say you can slap it on drywall or wood direct. I was thinking of adding some house wrap or foam for more protection.
You can add metal lathe, or go to the wood.
I could add house wrap the lathe the motor/stone.
1 - 7 of 7 Posts
