1 - 8 of 8 Posts
Hello~! I have an outside spigot that is leaking. Here is the photo. I've done research and I've read to just turn the spigot with a wrench and it should come off, but I haven't seen any that look like mine. I've also tried and it doesnt budge.
Do I have the kind that I can just turn or do I have to cut and all that? I cannot get behind it b.c. everything is in the wall.
Thank you~!
· the Musigician
if it's in such bad shape inside (corroded/pitted. etc.) that replacement is necessary, grab a pipe wrench, position the jaws over the USA on each side and rotate CCW, it will unscrew.
DM
· GC/Master Plumber/Mech
I'd replace the whole exteerior hydrant. That is and older hydrant because that "thingy on the end" is a vaccum break and most of todays hydrants have that anti-siphon break built into the hydrant.
If this in a crawlspace slide in and remove at the connection. Please don't just try to CCW turn the hydrant because I have had to go and repair the line that feeds the hydrant from being twisted.
just my $.02.....replace
1 - 8 of 8 Posts
