I'm installing a water feature in my yard.
Here is what I would like to do...
I have a GFCI circuit and a receptacle to the left of my patio door. I will add this to it and use 14 gauge THHN wire to branch from this receptacle to my water feature.
I plan to use schedule 80 PVC pipe and I have marked on my photos where that will run.
As you can see, I would like to take it down and put underneath my door, in the gap (1/2 pipe fits with no problem) and I will only use 3x14 gauge wires (1 circuit) to the water feature. I cannot go directly underground as I have pavers, and cannot dig those up. Going up would also be a problem and add to this run.
Is this ok to do? as the pipe will be recessed into the wall, there is VERY little chance of it ever being damaged, and using schedule 80 obviously makes it stronger.
My other concern is where to mount the new receptacle. The photo shows where I would like it to be, and then I can plug my pump into this (on the outside, back of the water feature). Any concerns with this? Does it have to be a minimum height from the ground?
Also, after the schedule 80 goes under the door, it will enter through a retaining wall that slopes down very quickly (about 3ft drop over 3-4ft distance). If the pipe has to be buried, what is the minimum depth?
Due to the route, I will need to add 4 90 degree elbows. Is that ok?
I appreciate any thoughts and suggestions.
