Hey all,
My outside faucet doesn't leak when turned off but it gushes water all behind the handle and plastic ring when turned on. I watched videos on how to replace the washers inside and/or tighten the nut but I think I want to just replace the whole part where the handle/stem attaches to the rest of the assembly. Like she did in this post: https://www.uglyducklinghouse.com/how-to-fix-leaking-outdoor-faucet/
Here is a pic of mine:
A) What is the name of the piece i need to replace? Valve handle and stem? Can I order one online as long as I know if its 1/2" or 3/4"? To determine that, do I just measure the opening?
B) I have tried loosening the nut but have been unsuccessful and am not 100% sure on which way to turn it tbh. There is writing on it that says "Left Hand Threaded", but when I tried turning it both ways, it started turning the main assembly at the brick which is no good, so I am looking for suggestions on how to loosen and remove the piece. I tried using channel locks on main assembly which helped some but without committing 100% on which way to turn, I decided to wait and ask.
Thanks in advance!
Thanks in advance!
