I have about six outside corners, plus about 30 feet of soffit corner to install today. I am using the steel corners. I bought some 1 1/2" roofing nails for the ceiling corners, and some one inch for the 1/2 inch drywall. I also have a pneumatic gun that shoots one inch staples but I am thinking I need longer staples? Anyway, are roofing nails fine for this application?
I always make sure the corner bead has a stud to nail into throughout. Drywall does not hold anything. I use drywall nails. I guess roofing nail would work but the head is big. Maybe just use a couple roofing nails then use stapler.
When hanging corner bead use a mudding knife to make sure it is sticking out far enough.
I haven't used metal beads for a couple years but when I did I always used drywall nails. I'm not sure, but if I remember right, roofing nails have a bigger diameter, and may pull your corner bead out of shape when you start nailing. Don't think I would use staples in metal bead. Staples are used in vinyl bead and they are only to hold it in place till the adhesive dries.
All in all, over the years, I have had very little problem with drywall outside corners. Of course, you must adhere them straight, square, and use a reasonably amount of fasteners (screws, drywall nails, roofing nails). I have seen very little failure with the outside corners of drywall.
Drywall screws or drywall nails. I think I used screws on my last major repair. Drywall nails have a thinner head than do roofing nails, therefore, they're easier to hide under your mud. And they're inexpensive.
