1 - 12 of 12 Posts
In my remodeled bathroom, I've tiled around the corner from the shower to the toilet area.
Opinions on whether or grout or caulk the outside corner joints?
It doesn't show up well in the photo but the narrow vertical tile is bullnose.
Thanks.
Naildriver
Color coordinated grout caulk would be my choice. It remains flexible but looks like the other grout lines. Use it wherever you change planes.
Reactions: ZZZZZ
Technically you could use caulk at every change of plane, but I've found some of them don't matter much. Personally I would grout that, especially if the wood framing is years old.
Discussion Starter #4
Underneath, I've got a layer of Kerdi over drywall. The framing is 35 years old.
Inside corners are tile to tile—would you grout that too?
I don't know who you're talking to. I assume you're talking to udraft, who seems to have the wrong guideline in place.
As chandler said, as a general rule you can caulk wherever there is a change of plane. I make exceptions based on experience.
We generally caulk inside joints, because the walls can move independently. The outside corner joins over a single wall.
Naildriver
I agree with Jeffnc on this, although it is a change of planes with two distinct walls that could pull against each other, but not likely due to framing.
Reactions: ZZZZZ
1 - 12 of 12 Posts
