Hello,
I noticed last night while my A/C was running that the outside unit fan was not running at all. The unit was very hot to include the exterior casing. I turned off the A/C and pulled the outside fuse to the outside unit. I've paid for a spring checkup that I've not called on as yet and am wondering what situation I may be up against, that the technician should be looking for?
Regards, Tom
thanks yuri...I'm remodeling the house and had some of the rooms shut off due to non-use by plugging the air ducts with towels and am wondering if this might have caused the problem. Not enough sufficient air flow getting through?
· In Loving Memory
That didn't cause the outdoor fan to stop working.
But can do damage to the compressor, which will be far more expensive to fix.
