1 - 9 of 9 Posts
Afternoon all, remodeling entire kitchen and want to do under cabinet lighting (maybe some in cabinet also). What do you all recommend for wiring and/or type of lighting. I would want something that can be dimmed (and most likely hooked up to some type of zwave switch). I know that some LED strip lighting can get very expensive while I see deals for LED lighting for very cheap. Any recommendations for brands? I know some of the cabinet places I went to offered to install lighting, but I'm skeptical as to the quality.
Also, is there any alternative to the electrical outlets every X feet per code? The aesthetics of the outlets are not appealing.
i gutted my kitchen to studs. i ran 120v outlets to each cabinet bank, 3. 1 outlet inside a cabinet. all connected to 1 switch. i used $40 each led multi colored & dim-able for each bank. transformer is just in the back of the cabinet plugged in. drill small hole on the back for the low voltage light wire AND the sensor ! then just put the led's where you want them and run the wire.
1 - 9 of 9 Posts
