Hey Guy's a few questions, and sorry for the long wind !
So I'm used to UK, ring mains and not this new fangled NA stuff LOL
So house from new (builders) 2006, -Canada- with a basement upgrade (fuk! up to some extent), I'm not certified, I'm an electronics engineer, from college.
So that said.
I'm recently delving and finding out about NA wiring, I've noticed that in the UK, we separate the lighting from the "ring" mains. Usually all mains sockets (outlets) have 13A sockets. Lighting is usually a lot less, I'm guessing, maybe 10A's.
So it kinda blew my mind that they have a string, of either 15A or 20A, and that can be a mixture of either lights or outlets. When electricians have come in to add a socket, they just TEE in to the closest point, it seems ! I Think there is some kinda formula as to how many outlets you have have chained on one fuse.
Looking at the fuse board the vast majority are all 15A's with a few 20A's , they tend to be in the kitchen, on the counter tops.
SO far we have never had any "trips" downstairs, regardless of what equipment we fire up.
However, the upstairs is a different matter.
It seems that there are 2 circuits up stairs both on 15A, NOW, I don't see a problem, with putting a electric heater in one bathroom and another in the other one. BUT when we do that, the breaker will trip and half the lights and both bathrooms go dark !
Also any combination of hairdryer, Iron, heaters etc, will do it. It wasn't a problem when my wife lived on her own, but now with a kid and me, using 3 rooms. We end up having to yell at the other saying, "let me know when you've finished with the "iron/heater/etc"
We've gone LED the whole house, so that has saved a bit, but still its a problem.
Also the master bathroom has a GFCI, which runs that whole circuit, including my one, which in my bathroom there is NO GFCI, just a standard outlet, (I'm not sure if the main breaker for that circuit IS a GFCI or not)
I've also learned recently about 20A outlets looking different, (they have a T cut into one connector) so that's how you differentiate between them, I found that my electricians actually used 20A outlets on a couple of 20A circuits I wanted in the basement, and also the builders did use 20A outlets on the counter tops.
The Outlets upstairs are all 15A including the GFCI. So here we go
1> Will it be expensive to SPLIT the bathroom circuit into 2, to stop breakers going
2> How much leeway is on a 15A socket ? If the breaker is 15A, does it blow, bang on 15A
2a> Is it dangerous to replace the 15A with a 20A breaker
2b> What is the cabling rated at, is it 15A
2c> I understand the breakers protects the cable from fire
The Outlet in my bathroom:
1> Would changing it to a 20A outlet be of any benefit
2> The existing 15A socket looks like there is some browning near the contacts, but no arcing seen
3> The heater when plugged in on full tilt the actual plug get's damn hot, when I turn it to half or quarter it cools down
I was looking in Rona, all the 20A's outlets I saw were all GFCI, the none GFCI, about 4 different styles were all out of stock. As my original game pla n was to swap it out for a 20A
SORRY for the long tale, but think it's important for the detail.
So that said.
