There is 2 outlets in the room. I plugged a portable AC into 1. Middle of the night, AC was off. No power on that outlet. The other one is fine. Checked the breaker is fine.
What caused it?
Loose/dirty/corroded splice somewhere
Heated up under load and failed.
Have you pulled the receptacle off the wall
look for back stab connections loose slices
or any signs of distress such as over heated wires.
Are you sure there are no hidden gfci's lurking some where ?
it's a very common problem.
