1 - 10 of 10 Posts
Two bedrooms upstairs... the light switch in one of the rooms not only controls that light, but also powers two outlets in that room and two in the other upstairs room. I would like to get rid of the switch controlling the outlets altogether without running new wires.
I took out one of the outlets from the other room and the light switch that controls it. Here is what we have...
Outlet box: 1 black, 1 white, and 1 green
Switch box: 3 white coming in that are all nutted together, 2 black coming in that are nutted together, and another black coming in that goes directly to the switch
Help!
Thanks for any thoughts!!!
Super Moderator
Depending on your location the code may require a switch controlled receptacle.
Help!
Are you sure you have only one black conductor going to the switch? Does not seem possible. You should have two conductors going to the switch if it is a single pole switch. More if it was a 3-way or 4-way switch.
Anyway if it is a single pole switch just take both wires off the switch and wire nut these two wires together and get rid of the switch. Now you will need a blank cover for the box.
Take wires "A" and "B" off the switch and wirenut "A" and "B" together. This takes the switch out of the circuit. Now find a blank cover for the box. Jim Port does have a point about a switch controlled outlet...say for a light....being in each room. Do the two rooms in question have different accesses or is one room accessed forom say the rear of the other?
Discussion Starter · #6 ·
The problem is... I still want to use the switch for the light in that room, I just don't want it to cut the power to the outlets when it is off.
Also, Hammerlane... you are right. The 2 black that are nutted together have a red coming from the nut to the switch.
Super Moderator
The two black that are nutted, do they connect to the switch? They should. Take one of them and connect it to the other terminal of the switch with other black wire. If the wrong device is on all the time you got the wrong wire. Put it back on the other switch terminal and move the the other wire.
Discussion Starter · #8 ·
Thanks Joed!
The two black ones that are nutted are connected to one of the switch terminals with a short piece of red wire.
So... what you are saying... take one of the nutted black wires and run it directly to the same terminal of the switch that the other black wire is already on? AND, leave everything else connected as it already is?
If it looks liike this
change it to this
You have a 50/50 chance that the recepticals will be continuosly on or the light. If wrong try the other black wire. Hint mark the black wire from the power source before you start. I'm going on the assumption who ever wired sent one wire up to the light and the other down to the recepticals.
Thank you hammerlane for the drawing.
Discussion Starter · #10 ·
I did it as you guys instructed and it worked. THANK YOU!!!
Now, tell me that this is a legitimate long-term fix and that I don't have to worry about a "faulty wiring" fire or anything.
Thanks again!
1 - 10 of 10 Posts
