is this generally a bad practice?
Bathroom receptacles have to be fed from a 20A circuit using 12ga wire. You may share that circuit with other bathrooms as long as you only have receptacles on the circuit. You may also have everything in one bathroom on the same 20A circuit, but it must feed only that bathroom.however, i was told to have bathroom/toilet outlets on a circuit of their own because a blow dryer can use too many amps.
