Hi, all! I am new to this forum. “Hardcore” diy’er, but not great with electrical..after almost burning down our house at age 6 when I decided to put all kinds of things into an electrical outlet...got a “deserving” ass whooping from my father and have shunned everything electrical ever since.
Here is my scenario: 20 year old house...I flipped a 3 way light switch on upstairs, and the light went black in the hallway upstairs and for some reason the lights in two other rooms no longer worked, but 3 other rooms still works. No breakers tripped. No problems with downstairs.
I switched the breaker on and off, and lights would work, but will stop working again. I found some loose wires inside the 3 way switch and tighten the cap...everything worked, and I figured problem solved...not so. The other day stopped working again. I used an outlet tester and found two bad outlets in the hallway upstairs. The tester stated Hot/Ground reverse, but has since learned that these testers should be given to kids...all wires are hooked up right. I used a digital voltmeter and all breakers tested good. The voltmeter only reads 1.5v when testing the outlets Hot and Neutral wires...Hot and Ground reads 120v....Neutral and Ground reads 100v. I don’t think it’s the two outlets themselves, and I’m leaning towards the neutral wires...BUT I have no clue what to do next, except from calling an electrician. Long shot, but hoping someone with electrical skills/talent can tell me what the problem is. Stay healthy and safe!
