Noobie question -- my apologies in advance.
I am trying to replace an outlet, which I have learned: 1) is part of a series wiring (i.e., connected to 3 other outlets, ugh!); 2) lives within a metal outlet box; 3) has ground wires that are hidden behind said metal outlet box. That is, I can see the ground wires, but they are tucked behind the outlet box, which keeps me from connecting the ground wires directly to the outlet.
I assume the person who wired this outlet intended to use the outlet box to ground the outlet. My question -- do I just ensure a connection or contact between the green ground screw on the outlet and the metal box? Is there a proper (or, maybe more importantly, improper) way to do this?
I understand that a parallel configuration would be superior, but I'm in an unfortunate situation of working with what I have. I have one outlet that appears to have failed, which has knocked out the 3 other outlets in the series. I tried replacing the outlet once before, and thought I had grounded the outlet by ensuring contact between the ground screw/terminal and the box, but after two weeks of working fine it failed again after plugging in a new appliance. I don't know if I ruined the outlet, or if it's just not properly wired/grounded. Any advice about ensuring a safe configuration is greatly appreciated.
