We are remodeling our kitchen. We knocked down a wall to the adjoining bedroom to make the kitchen larger. The dimensions are approximately 10' x 22'.
Here is a layout of the kitchen:
There are two existing light sources, one in each room. Do I add recessed lighting & keep the existing lighting? If I do add recessed lighting, where do I locate them? My next question is how many outlets are standard per breaker? Where do I locate the outlets? IE one outlet per ___ feet per wall.
Any help would be greatly appreciated! :confused1:
Here's a copied diagram for the location of the outlets.
Kitchens are very specific with wiring and I'm not an electrician, so...
There is no maximum number of outlets on a circuit and you may place as many as you wish. I usually limit it to around 10. Kitchens require (2) 20 amp GFI protected circuits for the countertop and nothing else. Use some common sense, if you plan on drawing a lot of power, run another circuit.
· Super Moderator
You counter needs a GFCI receptacle on every section of counter that is 12" or larger. A receptacle must be within 24" of the end of each counter and then every 48".( The actual rule is no secton of counter can be more then 24" from a recptacle. 48" inches is the middle and 24" away from a receptacle measured either way.)
By my count you need 11 counter receptalces and a fridge receptacle.
· Banned
I added recessed lights (CFL) in my kitchen & left the existing light (on a fan - now a CFL bulb). We turn the fan light on sometimes if needed
I think for countertop recessed lights every 2' is "normal" ??
I put 2 on one side - covering a 5'+ counter
On the other side I also put 2 recessed lights in - covering mnore area
In addition we have under cabinet LED puck lights
I'll be adding 3 more recessed lights on a counter that borders the new sunroom. All the recessed cans are 4", which I think looks better in a small kitchen VS 6" or larger
Our kitchen is maybe 10' x 14' without the sunroom
You can always turn a light off if not needed
But harder to put more light where there isn't a fixture
· Super Moderator
Recessed light spacing depends on the size housing, trim style, bulb style, mounting height and room layout. Without more info it would be very hard to do the lighting layout.
