1 - 6 of 6 Posts
I would like to install a GFCI outlet on the side of my bathroom vanity cabinet. Is this permitted by NEC? Any extra rules relating to running the wire? Thanks
Master Electrician
Are you planning on installing the GFCI on the cabinet itself, or beside it?
I don't know of anything in the NEC prohibiting this.
How do you plan on running the wire?
Any chance of a picture? :)
remodeling pro
There is nothing against this, but any exposed wires in the cabinet must be encased in conduit, either flexible or ridgid. We install outlets in the sides of cabinets all the time for kitchen islands.
Discussion Starter #5
Thanks for your comments. It will be used for a hair dryer, mostly. There is a tall linen cabinet next to the counter. I will run the wire up from the basement (using conduit :) ). The outlet will be recessed in the cabinet itself, just above the counter level. I think it's a go. Any other thoughts?
remodeling pro
Just installed two exactly like that in a pair of tall linen cabinets flanking the vanity bowls. For a really neat job, or just to be anally retentive like me, do what I did. First, locate the outlets within a couple of inches of the rear of the cabinet. I then took a couple of pieces of 1 by material and made a little 3 piece box, two sides and a top, to enclose the outlet and wire from view. A couple of beads of adhesive caulk will hold them in place, yet allow for prying them loose should it ever be necessary. Even though you will be the only one to probably see them inside the cab, it will make you feel good every time you open the cabinet and do not see an ugly electrical box and conduit.:wink:
1 - 6 of 6 Posts
