Hey All,
I have been googling and searching this forum but was hoping for some help with running an outdoor circuit. I am located in northern California. I am not pulling a permit but do want it to be done correctly.
I am adding a water feature to a sitting wall I built and it will require a small pump. I have future plans for an outdoor kitchen area that will have a refrigerator and a couple of led lights. To get to where the water feature will be, I will be pulling wire past the location of the future kitchen, so I want to stub up power at that spot to have when I do attack the kitchen project. To get power, I plan on tapping into an outdoor gfci on the back of the house. That outlet is on a 15 amp circuit. Its about 40' from the current outet to the water feature and about 25' from the outlet to the outdoor kitchen area.
I am still trying to figure out the most efficient way to run the cable and which conduit or cable to use. There is no room to get a trencher in to where I need the line and the dirt is HARD and rocky. Direct burial seems to be the easiest but I dont like the idea of the cable not being in some sort of conduit for protection purposes. Maybe I am overthinking it, but Im worried about accidentally hitting it later. Also, there seems to be conflicting information on the depth requirements of the different options.
Questions:
-Is 12" depth all that is required since it is 120v, gfci protected, and less than 20 amps? If so, can I put the cable inside conduit too, just so its not quite as easy to put a shovel through the wire? Or if I use conduit, should I just be using thhn or thwn?
-Rigid metal conduit can be as shallow as 6"? Are there compression type fittings for this conduit, or does it all have to be threaded? Should I just be using pvc? Since its a pretty short run I dont mind spending a bit more to do it better.
-Im assuming I would just use some sort of outdoor junction box to stub up power for the future kitchen and at the terminal location where the water feature pump will be. If I go direct burial, I will use conduit wherever the line cable comes out of the ground.
Any help or advice is appreciated. Im headed to HD to stand in front of the electrical fittings trying to see see what fits together. :laughing:
Questions:
