1 - 7 of 7 Posts
Hello!
I have two outlets outside (one in back and one in front) that do not work. The wires for each come from a single gfi located in my basement. When I tested the gfi it worked properly but when I tested the outdoor outlets it read open neutral. I opened the gfi and checked to make sure all of the wires were secure and everthing looked tight. For each connection (black, white, ground) there is one wire from the gfi crimped to two wires (one for each outlet).
The white seemed a little loss so I pulled off the old crimp and replaced it but now the outlets outside read open hot. The gfi still works but not the outlets after it. Any ideas? Should I call an electrician?
Master Electrician
Turn the power off. Remove GFCI from jbox. Note and or tag load and line wires connected to GFCI. Remove wires from GFCI. Temporarily connect black to black and white to white at GFCI jbox. Restore power and check downstream receps. If the dwnstrm receps are working, cut power, reinstall GFCI, turn power back on and recheck dwnstrm receps. If not working,cut power and replace GFCI.
I also wanted to ask about the splice. Once I figure out the issue and go to put it all back together, do i have to use a crimp or can i use a wire nut? I don't have the proper tool for the crimp but would be willing to pick it up if I must.
I=E/R
Nuts are fine...
Thanks for the help. Looks the GFI went bad. I replaced it and reconnected the crimped wires with wire nuts. Everything is working great...thanks again for the advise.
1 - 7 of 7 Posts
