Yes.
But you'll still have to find where the mystery one is.....
Would you believe...NEC 1971 code outside... 1987kitchen.Thanks, Jim. The house is fairly new - 14 years old. Maybe it's just old enough not to require the outside GFCI's. Good point about how outdoor outlets should be. I'll check with some buddies for help on correcting this (they know what they're doing).
Changing any other outlets connected to the two small appliance circuits in the kitchen I would say absolutely. For a quick fix where the outside receptacles are connected to inside wall circuits, installing a GFCI outside in parallel with those general branch circuits would be one solution. The outdoor overload would trip the outside GFCI and not the inside overcurrent protection device.Wow! Better get them changed. Would you guys recommend outside outlets be re-wired so they aren't "tied in" with inside devices?
