1 - 16 of 16 Posts
So I bought these to replace existing lamps: http://www.amazon.com/Royce-Lighting-RL2-1505-09-Outdoor/dp/B00138VTSA
Quick background: Just bought the house, wanted to update. Automatic garage door opener. When I opened the door (not main door, regular entry swinging door) I would hear a click and the outside light and main automatic light would go on. I took the left old light off, two (white) power wires touched and sparked. I obviously realized I didn't shut off the main power which is separate from the main house. I shut down the breakers. This side had two white and two black wires. The new kit also has a built in ground. I connected the one white (from the new unit) to both the white (from the garage existing wiring) and then the same thing with the black. I go to the other side, only one each (white and black) existing garage wiring. I wire them up (white to white / black to black). Turn power on, nothing. I hear the same clicking, but now the main light doesn't go on either, unless I hit the open or light button on the actual opener.
Today, I take them off, unscrew wire caps and disconnect. I hook the Fluke DMM and it is reading .566 - .667 Hz AC current. The breakers appear to be OK. Can anyone throw me some tips here? I know it's a long description, but I tried to be as accurate as possible.
· " Euro " electrician
Did you have motion sensor switch installed before ?? I think some case if sparked pretty hard sometime you can toasted the motion sensor { few will not take a surge or light to med short circuit at all }
Do not use the HZ scale just use the volt scale on your DVM and before you use it in the garage read it in the house first to verify it is reading correct then go in the garage and check it out and tell us what place you took the reading.
I will post a quick simple test.
• Black to white -- what voltage ??
• White to bare or green -- what voltage ??
• Black to bare or green -- what voltage ??
Those will give us the answer what you are looking for.
Merci,
Marc
Reactions: Breakthecycle2
If the lights are controled via the garage door opener,
Then it is possable you have damaged some tracks on the board.
The clicking you are hearing is probably the relay clicking in.
But the power is probably not getting thru,
due to a damaged circuit board
probably blown tracks.
Discussion Starter · #6 ·
How can I determine if it's bad? If so, how do I replace it?
Merci,
Marc
Will do this, this afternoon and report back.
Discussion Starter · #8 ·
Merci,
Marc
Yes, there is a motion sensor present.
Discussion Starter · #9 ·
OK, well: The house has 122V.
The garage door opener has 122V. The motion sensor has 122V but even after changing light bulbs it still doesn't work, but seems to have power.
The light unit with two wires has .5xxV and one has 0V. I cannot find any relays or fuses anywhere.
Here's some pics.
Discussion Starter · #12 ·
Have you checked for a circuit board in the motion detector part of the light fitting,
There will be either a relay or a triac in there that turns on the light.
Check this board for damage.
Actually, I finally figured it out. It is the motion light. It's fried. I unplugged the wire for the outside lights from that (see pics) and plugged it directly into another outlet and they work. I have to pick up a new motion sensor tomorrow. Thanks for all your help.
1 - 16 of 16 Posts
