I have looked through these forums and the internet and found hundreds of close answers, but no definitive answer. With that....
I am installing an outdoor hot tub (obviously). It will be on a concrete pad with 5 feet of 1-1/2 conduit underground, entering the house above ground level. The main breaker panel is 15 feet away inside. On the wall out side i have put a C/H 50Amp Spa panel (with GFCI/disconnect). I have 1-1/2" conduit running up to the disconnect. All standard, but here is the question I can't get a straight answer to:
I need to use 6 gauge wire - however, I understand I can not use 6/3 NM-B or UF-B in the conduit. I understand that I need to use individual 6 gauge THWN wire in the conduit. Am I right to understand that I can not run the individual wires along the joists in the basement outside of conduit? If that is so, then it would mean I need to either run conduit from my main panel to the disconnect and then from there to the spa, or I need to run NM-B to a junction box, connect it to THWN and then out through the conduit to the hot tub. Is that correct?
Since it sounds like no matter what I'll have to use the individual THWN wire, does it HAVE to be indiviual colors, or could I get a bulk spool and identify each of them separately?
edit>> I just found this:
Color Code
In addition to the identifying markings described above, NEC also requires that the insulation on individual conductors be color coded in order that conductors being used for certain specific purposes may be identified.
NEC 250.119 states that the grouding conductor may be bare, covered, or insulated. When covered or insulated, it shall be colored green or green with one or more yellow stripes.
Article 200.6(A) states for sizes AWG 6 or smaller an insulated grounded conductor shall be identified by continuous white or gray outer finish or by three continuous white stripes on other THAN green insulation along its entire length. Wires finished white or gray but with colored threads showing are permitted. With mineral insulated metal-sheathed cable mark the ends at the time of installation.
NEC 200.6(B) states that for sizes Larger than 6 AWG if the insulation is not colored along its entire length per (A) above then it must be marked at its ends per Fig. 4-5.
end edit
I have a good working knowledge of these things however I want to make sure that things are correct. I not aware that UF-B could not run through short conduit outside since it does not have an insulated ground, even though the outerjacket is probably even better protection.
Thank you in advance.
Color Code
end edit
