I have post lights and outlets outside that come on when the switch in the garage is flipped. Replaced with new post lights outside. When the switch is flipped the post lights come on but now the outlets do not work. Tried to reset GFI button but stays red. Outlets worked fine 1 hour before I changed out the post lights.??? Looking for ground on post lights touching hot or neutral?? Would the post lights work if this was the case? Not sure what to look for. I did replace old GFI with new GFI outlet- same result- will not reset. There is power to black wire of the outlet, just will not reset. Any ideas would be appreciated. Thanks
