Yes you do toe nail into the ridge, it does look like expected, well, a little worse than I expected.Ok, we used the template, verified short to short and long to long lengths, then cut the long one 179” at its longest point. Wedged it in at the top, and got the following at the bottom:
Of course I need to remove the wire that goes along the top plate, and then cut the opposite side.
No nailing to the ridge, only to the sister, right?
I would like you to measure the lift and try that same rafter on the opposite rafter to judge the back wall to the front wall.
If this is the worst section then we want to use the board with the highest crown.
