1 - 18 of 18 Posts
Hi there,
I am not sure if this is the right part of the forum to ask this but here it goes:
We're looking to build a backyard patio using pavers. My wife would ideally like to add a Pergola to it. From what little I know, I've heard that a pergola should be a certain height in order for the scale and perspective to be correction. The patio would be right behind out kitchen (no other options) and our kitchen has a big window looking out the back yard. I'm told that if we build a pergola of a standard height, the top will block the window. If we build it higher, the sense of scale will be wrong.
Can anyone share in more detail what is meant by the "sense of scale" being wrong? If it refers to the scale when sitting within the pergola, are there any tricks to hide this issue?
Would we have to raise the height of the patio to compensate? Since we're using pavers, how would that most easily and cheaply be accomplished? Perhaps by using cinder blocks under the pavers and then infilling with dirt or gravel and surrounding with wall stones? Or is that not a good idea? I imagine doing this against the house would not be wise ... maybe pushed back a few feet to avoid trapping water against the house?
Thanks for your time and patience with all the above questions.
I see what you mean now.
Several issues.
Your going to need to build a retaning wall on two sides.
Going to have to change that gutter down spout so it runs under ground.
And it will look strange having to sit up that high to clear that window.
· "You can do anything"-Mom
That seems like a lot of work just to have pavers. Have you given any thought to just building a wooden deck? That way you could keep the existing grade of your lawn and just compensate with longer support legs on the right side of that picture?
Are those sliding doors on the left side wall on that picture?
Yes those are sliding doors on the left.
Pavers seem much more inexpensive than to build a wooden deck, thats why we thought to go with pavers. The pergola isn't essential, so if we just went with the patio itself it seems pretty simple. But if we want a pergola, I imagine we'd have to raise the patio to make the scale correct. Would cinder blocks under the pavers do that OK?
In the picture it would be the right and area away from the house.
If there is no retaining wall anything under pavers is going to wash out.
I may be making this too simple but it seems to me that a nice option would be a deck that is the same left as those sliding doors on the left of the house. I'd put my pergola on that side then have a wrap around option maybe with steps down to another deck. Of course if money is tight that isn't the best way.
At any rate, maybe the creative juices might get flowing.
· Newbie Bill
Installing pavers (including a raised patio) on the slope that exists there now won't stay put for very long. Gravity and the effects of weather will cause them to move downhill.
The pavers need to be installed on relatively level ground (a very small slope to move water away from home is suggested) with the appropriate preparation materials laid and compacted before the sand base and then pavers.
You don't have very much room to build a raised paver patio as your siding looks to be only 5 or 6 inches above grade at the corner.
Discussion Starter · #15 ·
Oh OK I understand now.
Do you think pavers alone on the ground would work with that slope?
· Newbie Bill
I don't think the pavers would stay there very long, especially if you just put them on top of the grass.
I'm kinda lazy so try to do things right the first time so I don't have to go back and re do it. This is one of those examples where I wouldn't even consider paving (or a wooden deck) without the proper prep work. I would hate to have to pull up all the pavers in 6 months or so.
Here is an image of one layout showing a retaining wall on the downward side. You don't need the part on the right side of the image. The image illustrates some of the excavation that must be done for the retaining wall and the paved area. The gravel area is compacted.
Not at all, way to much slope and the patio would be useless.
Just go take a lawn chair out there and try to sit in it.
Discussion Starter · #18 ·
drtbk4ever,
I should have mentioned the pavers won't go directly onto the grass. There would be clearing/leveling of the area, sand compaction, plastic liners around the edges, and then the pavers (done by a local contractor).
Thanks for that image - its quite helpful to visualize!
1 - 18 of 18 Posts
