I recently removed the non-vented over the range vent hood to install an OTR microwave. I have mapped out every outlet and switch in the house, and the vent hood and now microwave are plugged into an outlet that was high over the range. Its a non dedicated circuit that starts over the countertop with a GFCI, has another outlet over the countertop, and then this outlet that the microwave is currently plugged into. The GFCI and last outlet on this circuit in locations that I really don't think I will ever use, and don't think I have yet. I have had the microwave about 6 months and have used it twice to heat water for oatmeal, (all new kitchen appliances, and I use my old toaster oven).
All the breakers are 20 amp, all the outlets are 15 amp, and all the wire is thicker than 16 gauge, (not sure if 14 or 12).
1. The microwave specs say 1000 watts / 13 amps at 120 volts. My math tells me 1000 / 120volts = 8 1/3 amps?
2. Its currently just me in the house for now. I can certainly get away with not using the other two outlets during the rare time I use the microwave. Are there any other concern that might come up until this is on a dedicated circuit?
3. I am about 99% certain this will need to eventually be on a dedicated circuit to be compliant. There is no dedicated microwave circuit in the kitchen. I have read someone say they were quoted $1,000 for this circuit. If I HAD to sell my house tomorrow. I would take a picture of it, measure it for exact dimensions, I would remove the other two outlets off this circuit and cap them off, then drywall and paint it before I ever paid $1000 for it.
I have other wiring (including the kitchen lighting) just ran overhead in the attic, and that would be my plan. My breaker panel has a breaker that is already there as SPARE. I have started with the outlets and switches, but running new cable and connecting to the panel is a step or two up from what I have done so far.
This seems like I would just remove the wiring from this outlet, run the new wiring to the breaker, and connect it. Is it as easy as figuring out how to do all that? Thank you.
