Hi!
I'm getting ready to install an Aprilaire 700 Humidifier on my Lennox ML 193 Furnace. When reading the installation instructions, it shows the 'typical' installation is mounting the humidifier on the face of the cooling coils. Basically, when you cut the hole, you should see the face of all the coils and not the triangle space of it.
I was wondering why this is, and if you had to. I'm also wondering how you know the orientation of the coil before you start cutting. I'm about 99% sure that it will be installed opposite of where the coil drains and the coolant enters. So, for example...
Am I correct in my basic example?
Thanks!
Code:
---Coolant -- | / \ | <- install here
---Drain ----- | / coil \ | <- humidifier
Thanks!
