If rafters are conventional and nothing else is supported by that wall. I would assume too and what can single width wall support? Still, I think it would do away with all doubt by cutting away small strip of ceiling drywall and make sure the rafter is same as others (assuming). If yes, then frame as you want without the header. Too bad that switch prevents you from getting rid of the whole thing west of the post for beam.
If that is a light switch (another one on the post?), is it possible to add a remote receiver for light fixture power cable and use remote receiver and switch? Maybe just add an outlet at the ceiling and change the light fixture into plug? Remote switch does need battery but with lithium replacements for conventional batteries, I think the batteries will last longer.
