Greetings,
I have just removed a (non-load bearing) wall between my living room and breakfast area and am in the process of creating an arched opening complete with a (false) header and recessed 1/2 wall book shelves. As I am not an expert I wanted to ask/address the following questions with everyone.
- Header Question. The header/soffit I am hoping to build will expand the entire length of the wall, but will have to be widened to match the width of the bookshelves. The width would need to be approximately 8''...which is wider than the wall that was initially installed. The problem is the header will run parallel with joists and I am unsure on how to secure the frame to the joists. Any thoughts?
- Recessed Shelves. So with the 1/2 wall I was curious if it would be easier to frame as if constructing a wall or go ahead and build the book case itself(out of hardwood) and use that as the "wall"?
