Hi,
First, thanks in advance for your assistance in helping me understand the following question that has me perplexed.
Suppose there are two wires, A and B, a DC power source, and a light bulb. Suppose both wires A and B have zero (0) voltage difference between them and the ground of the power source. Suppose one end of each wire is connected to the light bulb. Then, lastly, suppose only one of the two wires, say wire A, is connected to the hot side of the power source. One end of wire B remains open (not connected to anything), so the entire "circuit" is open.
Will the light bulb consume some power during the moment wire A is initially connected to the power source?
The reason I think it will is that wire A and wire B need to change electric potential energy (relative to the power source's ground) from zero (0) to the voltage of the hot side of the power source. In doing so, electrons will ultimately pass through wire A, through the light bulb's filament, and into wire B forming a higher electron density than before wire A was connected. That said, this electron motion against the resistance of the wires and light bulb consumes some, albeit, small amount of power (and maybe not even enough power to cause the filament to emit light, but still some amount of power that is greater than zero).
Is it true that there would be some current while the voltage initially equalizes.
Again, thanks in advance for you help.
