Line tester shows open ground on several wall outlets on same breaker. Test meter shows voltage across hot/neutral on all shows 120. Voltage across hot/ground shows 52/53 volts on same outlets. I tested all outlet hardware on good circuit and all show 120 volts with no open ground. In service panel I tightened all neutral and ground leads paying particular attention to the circuit and breaker in question.
I have never seen this before and I am looking for any suggestions.
Thanks in advance! TM
