Last year I put in some major yard drainage. It works, no more soggy yard, however, instead of eliminating one issue, it added to it.
Pics of last years work(2 pics):
The issue is the patio/door area, seen in the above pictures. That area has always had water collecting in it, even before I put in the yard drainage. I am now confident it is a combination of ground water and water from my yard drainage. Anything that is too low to enter the yard pipe, has a nice channel to that area.
Picture of the patio area:
I originally cut a hole in the concrete and planned to place a sump pump, however, I eliminated that idea because I did not want to have an exterior sump pump that would cause many issues in my crazy PA weather.
This year I started digging around the patio/door.
Digging progress(3 pics):
My current plan is to do an open french drain around the patio, through my driveway, then to the street. I cannot tie into my existing pipe because this new drain is at least 12" lower.
The plan:
What do you think? I will be using perforated SDR-35 and non-woven geotextile fabric again.
I also need to rebuild that cinder block patio and pour a new top, ill probably make a seperate post about that
The plan:
